Thinkcar Pro Flashing Scheme
  • Автор темы Автор темы BatuhanK
The problem is, if you have flashed the firmware and something does not work, you can no longer flash back.
Very good my friend, could you tell me where I connect the positive and negative on the PCB? because through the 16-pin obd2 input, the device does not turn on to boot. Could you identify the positive and negative soldering points with photos? and are swclk, swdio and reset correct? If you can help with images I would be grateful and congratulations on the initiative.
