It is not problem in android version.Xiaomi redmi not 12pro 5G 14 android work!
Hi bro. did you found the solution or no. I also have poco x6 pro and app still not installedSame problem here, Android 14 on POCO X6 Pro 5G, maybe it's a problem from Android API service for 14 not include in last version of Diagzone Pro, just wait for next update of Diagzone Pro, now i'm using Redmi Note 9 on Android 12 and it's run fine![]()
I am not find solution for this problem? But I find it strange that the administrators of the diagzone pro application have not yet made a solution for this problem, several months have passed and there is still no solution.Hi bro. did you found the solution or no. I also have poco x6 pro and app still not installed
Thank you for your answers bro, yes this is not professional from diagzone team,but we hope they solve the problem ASAP.I am not finding a solution for this problem? But I find it strange that the administrators of the diagzone pro application have not yet made a solution for this problem, several months have passed and there is still no solution.
You need to understand that diagzone app isn't built from scratch... They just taking already built app, making changes to bypass verification of interface it is working with, and make it work with their servers.. they can't build an app just because they don't have source code.. and I believe whole diagzone project will collapse soon, because admins not replying, there no updates for the app.Thank you for your answers bro, yes this is not professional from diagzone team,but we hope they solve the problem ASAP.
It won't fail for sure, and even with some small glitches or bugs like this, Diagzone is top notch and unsurpassed. Imagine how many people would have to be in the team to be able to respond to all the messages, criticisms or complaints, and still have to remain so cheap. I want to point out all the praise for their administrators, and I wish them success in their work...Morate shvatiti da aplikacija diagzone nije napravljena od nule... Oni samo uzimaju već izgrađenu aplikaciju, unose promjene kako bi zaobišli verifikaciju sučelja s kojim radi i učinili da radi sa njihovim serverima.. oni ne mogu napraviti app samo zato što nemaju izvorni kod.. i vjerujem da će cijeli diagzone projekat uskoro propasti, jer administratori ne odgovaraju, nema ažuriranja za aplikaciju.
yes the same problem on Poco x6 pro no way to install it even when try adb with pcI have galaxy s22 and install dz v2.00.029 without problem, but on s24 ultra no way to install, i try and with adb with pc and no succes.
Can you record video and share on youtube, or write solution on forum?Finally I found solution, I can run diagzone app on 64bit phone, I have Poco x6 Pro 5g and the app work perfectly, so for all which want the solution contact me on WhatsApp +393770801868
Contact me because it's so long to explain.
Thanks
snapdragon 8 gen 3 nepodporuje 32bitovou aplikaci, takže musí být čistě 64bitová a samsung do jádra nepřidal emulátorAhoj všichni, samsung galaxy s24 ultra cant install diagzone softwer, nějaké řešení tohoto problému?
