Semensowod
Doip не работает на синдиаг 2 хотя по проводу обновляет прошивку адаптера без проблем и приложение просить разрешение на порт но в любой марке ошибка соедининие прервано пишет
Yes Doip works only by wire. No Bluetooth.If you connect to the car via bluetooth, go to the brand where auto search or select manually and connect the bluetooth cable, you can turn it off, then the cable works and the diagnostics also work via wire
Klego który z tych kabli będzie działał z Doip??? Wcześniej kolega pisał że Doip działa tylko przez kabel. Nie działa przez Bluetootha .Eiag Plus =thingdiag2 = Uruchom DBSCAR VII = Thinkcar TVCI = TOPDON ARTHLINK 100
I didn't understand exactly if you said that it works connected via usb to thinkdiag2 or the doip adapter must be connected via usb.If you connect to the car via bluetooth, go to the brand where the auto search or vibrator is manually and connect the Bluetooth cable, you can turn it off, then the cable works and the diagnostics also work on the wire
Incearca un adaptor OTGThere is 2 versions of DOIP cable. This is the usb wire version. But only original launch tablet has this usb port.
On which tablet you use the doip adapter? The tablet has a large native usb A or you use an otg adapter? thank youWorks at least type with type with dance without bluetooth on the wire syndiag 2
