motorsportsz
Hi does anyone have diagbaseservice apk for diagzone V2
I keep getting diagbaseservice error because it is not installed.
Thanks
Thanks
Its an 'online coding' error at BMW ? Or what do you try to do here on this error picture you attached ?Does anyone has the answer to this case.. facing a similar issue.. need DiagBaseService for V2 ..
v 1.57 tryDoes anyone has the answer to this case.. facing a similar issue.. need DiagBaseService for V2 ..
yes, BMW... no problem on download data. but failed during coding process, getting error need to update diagbaseservice apkIts an 'online coding' error at BMW ? Or what do you try to do here on this error picture you attached ?
already tried. getting error no internet network connection.. seems the connection to server already closed for this old version..v 1.57 try
Nu diagbaseservice este problema. Aplicatia in sine nu functioneazaanyone have diagbaseservice apk for V2 ?
I think you are not on v1.000.057 please update to 1.000.057! Network error usually on the older versions than 057!already tried. getting error no internet network connection.. seems the connection to server already closed for this old version..
Băieți, ajutați cine vkurse. Trebuie să pun asta
DiagBaseService
Добрый день! Можете пожалуйста перевыложить файл или скиньте пожалуйста на emailDiagBaseService_base 1.00.010.apk
Deniskolobov91@gmail.com
Заранее благодарю
