If i downloald 11.85 resets it will work function pack?I have told him this many times, in RESET when you select for example: RESET OIL- AUDI you can't make a check box to select download additional Boot package, tested on more devices and also other people confirmed me, on same device same option works normaly on *****, so its not Android problem, problem is in app. So to be able use RESET functions, all which are 11.90 versions I need to download lower versions like 11.85 to be able use normaly.
ThanksYes sure, it wont ask you to download additional files.
