BMW - e-sys. Mercedes - Xentry, vediamo. Vag - ODISDoes anyone know how to start ecu coding and what equipment to use I am new to this platform if someone could explain it will be great thank you in advance
What about American I am from usaBMW - e-sys. Mercedes - Xentry, vediamo. Vag-ODIS
What are you planning to code in American cars?? There is not much room to play with in American cars.. you're pretty much stuck with near to factory configuration, can't really change muchWhat about American I am from usa
For example when replacing the engine control module or the body control module it needs to download files. My question is in this case will diagzone or familiar software do the job ?What are you planning to code in American cars?? There is not much room to play with in American cars.. you're pretty much stuck with near to factory configuration, can't really change much
No.. on Ford's you can go around with PMI.. on GM you can't program used modules on newer cars even with dealer software.. FCA - may be.. don't have much experience with FCA..For example when replacing the engine control module or the body control module it needs to download files. My question is in this case will diagzone or familiar software do the job ?
What is PMI?No.. on Ford's you can go around with PMI.. on GM you can't program used modules on newer cars even with dealer software.. FCA - may be.. don't have much experience with FCA..
Programmable module installation.. before replacing module you are reading config from original module, then swap the module and config you've read in previous step is loaded to replacement one.. can be done with IDS, Forscan.. in some cases can be done wit diagzone..What is PMI?
Another question, do you have experience using thinkdiag boot and thinkdiag 2? What are the differences.Programmable module installation.. before replacing module you are reading config from original module, then swap the module and config you've read in previous step is loaded to replacing one.. can be done with IDS, Forscan.. in some cases can be done wit diagzone..
If original module is not responsive you can always download as-built data for given Vin number and load it to donor module with forscan
Used to use easy diag 2.0, then switched to thinkdiag 2.. TD2 is much faster.. but you can't easily go back to original software once you've used TD2 with diagzoneAnother question, do you have experience using thinkdiag boot and thinkdiag 2? What are the differences.
OK so TD2 is compatible with diagzone for the software of easy diag 4? Or I have to buy different software to use TD2?Used to use easy diag 2.0, then switched to thinkdiag 2.. TD2 is much faster.. but you can't easily go back to original software once you used TD2 with diagzone
Td2 works with diagzone. But if you're planning to use it for coding/programming - it's not gonna work at this time..OK so TD2 is compatible with diagzone for the software of easy diag 4? Or I have to buy different software to use TD2?
Got it! Thank you for your timeTd2 works with diagzone. But if you're planning to use it for coding/programming - it's not gonna work at this time..
