Is it programmed with st-link or jlink programmer?HI
When i plug Mucar to TOYOTA the dashboard start flashing ABS lamp & check lamp,, , when i unplug it stop flashing ????????????
ANY IDEA???
Yes, everything work,only this issue with Toyota dashboard lightsSo it is just flashing dashoboard, but work good reading modules ?
If i unplug the connector and replug it it stop flashing an it diagnose normallySo it is just flashing dashoboard, but work good reading modules ?
So only first time do it? Second time no?If i unplug the connector and replug it it stop flashing an it diagnose normally
It always flashing it stop flashing only if i connect to the vci Bluetooth then unplug the connector then replug itSo only first time do it? Second time no?
So how long time have to wait to makes flashing the dahsboard again? Maybe something logic can be revealed.....
I sell Mucar bt200 programmed with diagzone and customers annoyed from it because of this problem so i need to solve this problemIt always flashing it stop flashing only if i connect to the vci Bluetooth then unplug the connector then replug it
We have similar dashoboard flashing on HD MAN truck , with Thinkdiag. Was no solution!I sell Mucar bt200 programmed with diagzone and customers annoyed from it because of this problem so i need to solve this problem
HI
ANY IDEA???
No solution for this! Also original software sometimes cause that issue!I sell Mucar bt200 programmed with diagzone and customers annoyed from it because of this problem so i need to solve this problem
not the same way like after reflashing with diagzone but also shows some issues, better not to buy this piece of sh*tTry plugging into OBD port and loading diagnostic software before turning on the key. As it is known the device acts this way with the original software ,it is not in the reflashing
Are you sure? I compare a Muchas Bt200 with Diagzone against a ThinkDiag with original Thinkcar software...mucar gave me false positive for 3 flashing light on dashboard.I have the same issue. But by the way the diagnostic run normal
