Help Diagzone does not read Mercedes CLK 200 38 pin to OBD modules??
  • Автор темы Автор темы Fafs
Fafs
Ayuda Diagzone (interfaz Thindiag) no lee modulos Mercedes CLK 200 (w208), 38 pin a OBD?? Compre un conector de 30 pines a Obd (solo tiene 3 cables (tierra, +12v y Linea), el conector hembra del carro solo tiene 11 pines activos, no se que hacer. Alguien me puede guiar para leer los modulos y funciones, o facilitar algun diagrama de conexion 38 pin to OBD? gracias a todos
    111,8 КБ · Просмотры: 3
    225,3 КБ · Просмотры: 3
    51 КБ · Просмотры: 3
Help Diagzone does not read Mercedes CLK 200 modules (w208), 38 pin to OBD?? I bought a 30 pin to Obd2 connector (it only has 3 cables (ground, +12v and Line), the car's female connector only has 11 active pins, I don't know what to do. Can someone guide me to read the modules and functions, thanks to everyone
That adapter will not work with launch. You need original one like one on the picture
    10 КБ · Просмотры: 12
  • launch-original-for-benz-38pin-obd1-cable-auto-extension-cable-adapter-38-pin-car-obd-extended.webp
    27,1 КБ · Просмотры: 12
