how did you sort it out m8 ?my one has the immo section but its not able to programme any carsSolved. Thanks Diagzone gang.
this guy said he solved it he has not replied back so i don't know which programmer u on about ?before all this immo function where working without any adapter sдля иммо прог нужен дополнительно программатор X431 PROG 3
yes me 2 its immo prog problem i tried the pm number but he's not reply to say immo prog is working or not any solution?You have two options, immo prog and immobilizer reset. My problem was related to immo prog.
thank but what i have noticed today is the Ecu programming section on most cars have disappeared or has been removed like the Opel/Vauxhall and land rover can you please check if your one has it?Immo prog reguires programming device xprog 3 to be in use. If you have immo prog software available, when you clik the corresponding icon in DZ, then it's asking to connect xprog3 and shows a picture of the connection. After that you can choose what you want to do. So which point is problematic?
ok can you try open the Opel /Vauxhall up see after it opening up what it saying? I get error saying (IMM not support this function) please check m8I have both, opel and land rover.
