Switch to English and redownload software.. and stop complainingYesterday I paid the 40 dollars to enable sgw unlocking, it appears written with the subscription deadline but it doesn't unlock sgw for me
Every single car is being unlocked with English software.. so try this firstHi friend....I explain a problem only my customers have activated many sgw subscription's all worked fine , I ask only why don't work. if for you this means complaining after paying for a service that is not offered.......
Then you're doing something wrong.. SGW bypass working absolutely fineТолько что опробовал - базы и программа на английском, DZ v27, подписка на Unlock SGW валидна. Результат - как в первом сообщении, хотя ранее при той же конфигурации, все замечательно работало. Такое впечатление что проблема между серверами DZ и auth
Hi, maybe can you also try now ? Still works or really stopped ?Then you're doing something wrong.. SGW bypass working absolutely fine
Will try tomorrow.. we have hurricane here, so we all are off till the end of the weekHi, maybe can you also try now ? Still works or really stopped ?
Это пока. Крайслер усилил защиту, на авто 24 года ничего не работает, кроме дилерской.Thanks problem solved , now work fine
