if your PC ARM base, can... but Intel Base, can not..Hi
is it possible to install diagzone on pc (andriod installed ) like bliss andriod for pc platform all other andriod app works on it
pls update if any one succeded and got it working on pc
thanks
hi thanks for that can you pls ADVICE WHICH PC ARE ARM BASED ? AS I HAVE DELL E6320 PC (I5) AND ONE IS HP ASPIRE BOTH SEEMS TO HAVE INTEL CHIPSET (I3) WILL IT WORK ON AMD A6 DESKTOP ?if your PC ARM base, can... but Intel Base, can not..
PC never use ARM, only tablethi thanks for that can you pls ADVICE WHICH PC ARE ARM BASED ? AS I HAVE DELL E6320 PC (I5) AND ONE IS HP ASPIRE BOTH SEEMS TO HAVE INTEL CHIPSET (I3) WILL IT WORK ON AMD A6 DESKTOP ?
That's the final answer no questionsAndroid emulators for PC do not support BT. So it has no interest.
PC only use Intel or AMDPC never use ARM, only tablet
PC can support BT via Android OS for PC ( Remix OS or Phoenix OS)Android emulators for PC do not support BT. So it has no interest.
