E edison New member 12.05.2024 #1 Puede cambiar algo del auto si lo utilizo con error El conector 12+8 Y como puedo tener el manual x qué no pude bajar
V virusmind Well-known member 12.05.2024 #2 edison сказал(а): Puede cambiar algo del auto si lo utilizo con error El conector 12+8 Y como puedo tener el manual x qué no pude bajar Нажмите, чтобы раскрыть... Please speak English.. I'm trying to translate what you are saying and can't understand what you want?? It can change something about the car if I use it with an error. The 12+8 connector And how can I have the manual because I couldn't download it?
