NicoGarage
Buenas tardes quería saber si se puede hacer codificación online de VW y de poder hacerlas como sería el procedimiento, muchas gracias
Ok. We can switch to English now. Back in the day there was no problem pulling factory long or short coding for vag, as well as login for various modules. but today it is a lottery.. sometimes it works, sometimes it doesn't. In today's reality it will be cheaper to use online geko access with odis to perform any kind of coding or component protectionДобрый день, хотел узнать, можно ли сделать онлайн-кодирование VW и какова будет процедура, большое спасибо, извинения!! Я опубликовал это на испанском!!!
As long as the module with cp enabled is not blacklisted(e.g. from stolen car), you can easily go around it with odis and online geko access.. hmu in pmThank you very much for your response, I just have a VW Polo in the workshop with a SAFE CP fault on the dashboard and here in Argentina they can only do telecharging at the dealership
