electron489
Hello I have opel astra h 2005 UEC module is broken change with new but I not have pin code for new module I have onli pin code of car , and how to take this pin code
Hello my friend. On this forum we are discussing capabilities of diagzone software and bugs in it. With your question you need to go to dedicated car diagnostics forum, or opel forumHello I have opel astra h 2005 UEC module is broken change with new but I not have pin code for new module I have onli pin code of car , and how to take this pin code
You can try to use special immo program for opel, it can read car pass from various modules (ECM, radio, ABS and BCM, for astra h you can try to read your UEC as BCM). Otherwise you need to work with EEPROM memory of your UEC, maybe desolder EEPROM from your old UEC to new one (of course if your EEPROM is separate IC). Then you won't need to rebind control module in car software and you don't need to know car passHello I have opel astra h 2005 UEC module is broken change with new but I not have pin code for new module I have onli pin code of car , and how to take this pin code
