Hi this thinkdiag brings with 11.91 original firmware, not working with diagzone.
We need wait until update diagzone firmware higher than 11.91?
No boss!Did it work finally?
have you tried to push to lower FW? or run firmware fix ... try all possibilities. I just bought thinkdiag with unlock chip.. i will receive it in a few days. let's see if I have similar problem like yours.no boss!
Firmware downloaded by diagzone is 11.87 and when firmware occurs, the firmware keep in 11.91... similar when device has a locked chip!have you tried to push to lower FW? or run firmware fix ... try all possibilities. I just bought thinkdiag with unlock chip.. i will receive it in a few days. let's see if I have similar problem like yours.
See the attached images! I did firmware fix twice buy when I do verification again firmware keeps in 11.91Firmware downloaded by diagzone is 11.87 and when firmware occurs, the firmware keep in 11.91... similar when device has a locked chip!
Remember leo says all are the same boot, difference is chip locked or not... This device is the first particularly I see with firmware 11.91.. the problem is that.. I think... Maybe in further it can be connected if chip is good, no locked! You can see all details from device in attached images!Are you sure its "old boot"?
No working right?I have 11.90
