Saltywhale
Hi, I tried scanning a 2016 Ford F-250, I tried the automatic diagnose method and also the manual local diagnose way, and this error code popped up both times no matter what I did, the basic EOBD function works fine. I also tried with an Autel scanner, and a Foxwell Scanner, but all the others couldn't scan it also, is this a vehicle-specific issue? Or is it an issue with the software these scanners share? Attached are the images of the code.
https://i.*****.com/DI3opAB.jpghttps://i.*****.com/VLLFKoM.jpg
Thank you for any of the help or for just reporting this vehicle issue.
