It wasn't the stamps that mattered. Android 10, the application itself is installed in the main memory, if you specify the data to be saved on the memory card in the settings, it is not readable. If in the main - it works
In Android 10 yes it work on sd card,but Android 11 not work sd card setting.I set it in the android settings - use the internal memory by default, and in the settings of the diagzone - ad sd card - it worked
