giorgikhachidze
Как вернуться к заводской программе? Или как сделать бэкап перед записью на Diagnos Pro
For what? If you already update Dz's firmware for your scanner, you can't rollback for use original softwareYou can take backup by app in google play #share apps pro
Then go to its folder you will find apk file for diagzone
no problem if you have thinkdiag plug. I did it many times and tried again with latest app Thinkdiag plus, you can rollback to official firmware from diagzone firmware using official app thinkdiag plus, and if you want you can return to diagzone . That's why for me thinkdiag is still the best plug. For thinkdiag2 the rollback not possible , need open and use j-linkProblem its firmware in vci not apk orginal Thinkdiag app dont see vci after upgrade to pro. Question is orginal app can repair vci firmware to work in orginal app ? I think this want know autor.
Это работает только со старым загрузчиком! Вы должны это знать точно!no problem if you have thinkdiag plug. I did it many times and tried again with latest app Thinkdiag plus, you can rollback to official firmware from diagzone firmware using official app thinkdiag plus, and if you want you can return to diagzone . That's why for me thinkdiag is still the best plug. For thinkdiag2 the rollback not possible , need open and use j-link
С новым загрузчиком невозможно пройти верификацию diagzone! Вы должны это знать!Это работает только со старым загрузчиком! Вы должны это знать точно!
